Moving flashing lights and reflective clothing
oxoman
2 things colleagues used say made them know it was me they were driving behind when I cycled to work everyday was spoke reflectors and a tiny LED light on my lazer helmet that appear to move up and down as I pedalled in. Still use them today but work elsewhere so no colleagues going past me.
N0bodyOfTheGoat
Hampshire, UK
I think bright and/or hi-vis on moving bits work really well on a bike, so obvious place is lower legs and feet.
I have...
Retro-reflective PlanetX toe covers.
Bright yellow socks, one pair have retro-reflective bands.
Boardman retro-reflective gillet/jacket, but it's a bit boil inthe bag unless it's proper freezing or I'm taking it pretty easy.
Black arm warmers with bright yellow sections on outer top arm and inner lower arm.
Bright yellow PlanetX Das Boots
All my jerseys have some non-black colour on them, usually quite bright
Rear section of my "bordeaux red" Abus Gamechanger helmet is pink
etc.
teeonethousand
I don’t ride in the dark because I don’t have to…but if I did I think I would wear lots of reflective bits and lights etc but I would also uplight myself. So, a small light or two facing up to/across me so that the reflective bits glowed all the time. Obviously not in my direct eyesight so downtube upwards, rear stay upwards, that sort of thing. It might also help with walkers spotting you because as we know they like to wear ninja dark gear and concentrate on phones whilst moving around.
Drago
A remember, of course, that standard yellow hi vis can actually have a camouflage effect in good sunlight in a rural environment, hence mountain rescue wearing red, etc.
The article indirectly raises a point so obvious that it goes over most people's heads - something done in intuitively in the name of safety rarely actually brings a sefty benefit, and can often make things worse (pver bright day time lights, for example.) If its not been unequivocally proven to keep you safer, it most likely won't no matter what the ingrained public perception may be.
presta
The brain has evolved to notice things that change and ignore the things that don't, it doesn't have enough power to process all the information all the time, so it uses most capacity where it yields the most benefit.
Chief Broom
A cyclist recommended to me to wear a hi-viz jacket rather than my Sam Browne whilst riding on the A9 in the Highlands in the day. I dont see any point in that as visibility in the day is good enough [for me] to see a pheasant half a mile away. The drivers that do dangerous overtakes/manoeuvres know im there and its there attitude that needs changing not my attire! Obviously extra lights/clothing etc could help in other situations im not doubting that :okay:
Jenkins
Felixstowe
The problem these days is how do you differentiate yourself from the the sheer amount of light sources that cars have these days? Full time DRLs, LED headlights (even in the daytime), ever brighter and larger rear lights, full width light bars (front & rear), illuminated brand logos and the likes of BMW with the illuminated kidney grill surround.
Ian H
Ancient randonneur
Decent lights and don't breakup your recognisable human-shaped sillouette with random reflective, flashers and other confusing stuff.
Once a Wheeler
…always a wheeler
I found motorists were generally better behaved around me at night when I wore an offside rear-facing red light strapped just below the knee. My impression was that it did not make me much more visible but that the up-and-down motion and occasional snippets of free-wheeling interrupted people's expectations and so made them consciously aware that someone was present. Anecdotal, but it seemed to work.
