I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
I did pick up a steel rod through the tyre on a commute in the early days. It was chromed and approx. ¼" thick, and originally about 2½" long! I say originally as I pulled a piece of about 1½" in length out of the tyre and fitted a new tube before continuing to work. At lunch time I fixed the damaged tube and lightly inflated it to check for any other holes. It was then that I noticed something rattling around loose in the tube, the other piece of the rod! I had to snip a little hole in the tube to remove the item then repair it againI've had an inch 'n' half wood screw, halfway round a roundabout (primary in middle lane, indicating left to leave on third exit) that was a bit instant but that's a real freaky one.
. The rod must have been thrust through the tyre and hit the rim before part snapped off inside the tube.That and the Stanley blade rate high on the freaky-o-meter of puncture experiences but as they both happened close to the Bredbury tip facility (probably the biggest (ex)authority controlled refuse and waste disposal site in East Manchester) not a surprise.
