Muc Off Ceramic Wet lube Formula Change ?
Quite a few years ago I switched to muc off ceramic wet lube when I couldn't find any finish line equivalent. I found it the same as Finishline and I preferred its applicator so I stuck with it (muc off). Before in summer I could go at least a week without cleaning and I was doing more substantial miles. Now Im finding the muc off goes dry and sticky after a short ride. Has its formula changed? Is it worth going back to Finishline?
Spiderweb
Not So Special One
North Yorkshire
I can’t comment on the Muc Off lube as I’ve never used it but the Finish Line ceramic wet lube is the best I’ve used, it definitely doesn’t dry up or go sticky.
