MrGrumpy said:Whilst mudguards ................they don`t half look rubbish![]()
GrahamG said:The track ends advantage is the chain tensioners - I'm sold since chain tension on my horizontal dropouts is a right pain in the arse compared to the old pompino!
Fixedwheelnut said:Try and get some old 'cyclo' chaintensioners for forward facing dropouts like these
As for mudguards, use the SKS front fixings on the rear as mentioned![]()
MrGrumpy said:As for mudguards, use the SKS front fixings on the rear as mentioned
you`ve lost me where was this mentioned ?
It was a couple of posts above, see belowAs for mudguards, use the SKS front fixings on the rear as mentioned
Green Teeth said:I have put mudguards (and a rack) on my Pompino. At the recommendation of someone or other on a forum I used SKS quick-release clips for the back as well as the front, so you can just pop it out of the way if you need to take the wheel out.
You can buy the clips on their own from SJS Cycles.
I find the mudguards essential for winter commuting, I just wish someone would invent a silent variety.
GT
