Ed no-more-lemons
- The Burbs
For a present as I use separate tools.Do I go for the one with the 8 mm hex or not? I cannot remember when I last used a 8mm one.
Thanx
Thanx
Some brake shoes and spring tensioners and what else?Make sure you have a 2.5mm allen if required. Some don't as i found out after a mishap.
Probably not, but useful when your pedal is becoming loose though (e.g. fits Look Keos)I don't know if a multitool would offer the leverage to remove a pedal.
I dont think so either but it could do one up if it comes loose?I don't know if a multitool would offer the leverage to remove a pedal.
Is the right answer. My multitool goes upto 8, by plugging bits of it into other bits. Adamski, from The Other Place, was ever so pleased it did once, just as an FNRTTC was about to start.Crank bolt.
Yes, the No 8 is usually a separate piece that fits onto the No 6 key. I once tried to buy one, searched the web high and low, assuming that it would be easy. Somebody must make and sell them somewhere, but I couldn't find one. Does anyone know where you can buy just the No 8 attachment?Is the right answer. My multitool goes upto 8, by plugging bits of it into other bits. Adamski, from The Other Place, was ever so pleased it did once, just as an FNRTTC was about to start.
