My appliances hate me...
icowden
icowden
Surrey
News update!
I'm pretty certain it's this wotsit that was causing the problem. I think age has withered it. It's the seal around the pipe from the cistern that pushes into the bowl. The waste is better as they used a concertina connection rather than just a rigid pipe with a wotsit on it.
However, I also discovered that those installation chaps at B&Q took a few shortcuts when installing the bowl. Spend ages trying to get out the two bolts that hold the bowl to the floor. I thought one had sheared off. Decided to poke around at the shear and discovered it was silicone sealant. Essentially they used sealant to hold the bowl to the backboard and the floor then used sealant to put the plastic retaining bolt covers in place so it looked nice.
That said - it was pretty rock solid for the last 10 years so it did work.
Anyway - offback to screwfix if I can find what the doodad is called. Then I have the fun of cleaning off all the sealant and redoing it.
CXRAndy
Lincs
I generally use silicon to stick down toilet pans and cisterns to the wall. Surface area provides excellent bonding
Don't like using screws with porcelain.
News update!
Could be it, we had a problem where over time the slight movement of the toilet pan from people getting on and off the toilet caused the pipe to 'walk' it's way out of the seal, causing the leak. A block of wood between the wall and the pipe solved it for me!
DRM
West Yorks
It still could be the micro switch. Mine look clean on the outside, but greasy steam finds its way inside and fouls the contacts. The switches are easy enough to open up and a spray of contact cleaner or emery cloth on the contacts will ensure it’s operating. Be gentle with them as the switch mechanism can ping out and is a fiddle to put back.
View: https://youtu.be/vPFhzX5Bheo?si=DmSqfpvvdpPMT74a
As a side note, another item that wears out quickly is the upper spray arm seal. It’s basically a large plastic nut with a rubber seal in the centre. When the seal perishes the top arm stops working. A 30 sec job to change and it washes a whole lot better after replacing.
One thing to remember with microswitches is when fitting a replacement, the 3 terminals are marked common at the bottom, and NC (Normally Closed) & NO (Normally Open) on the end, the manufacturers do love to transpose the NC & NO connections for a laugh, so you can't just copy the connections, you have to double check you're putting the wires on to the correct connection with regard to if the switch is breaking, or making the circuit
DaveReading
Don't suffer fools gladly (must try harder!)
Reading, obvs
It's normally referred to as a doughnut.
If it's still capable of sealing, you could be better off re-using it as a new one might be harder to compress to the same degree and then the union on the supply pipe to the cistern won't tighten sufficiently.
DAMHIKT.
icowden
icowden
Surrey
I thought the doughnut was for close coupled cisterns. This is an internal flush pipe connector according to Fluidmaster.
This goes over a 40mm pipe from the cistern to the bowl so the fault was the fins on the previous connector perishing over the years. The new one is on after a wrestling match and the toilet bowl re-sealed to the floor and backboard. 24 hours now before anyone is allowed to sit on it.
icowden
icowden
Surrey
Good to know. I've done the same as I don't have the floor anchors that would have gone with the bowl. I suspect that they also thought it was easier than trying to drill through the marble tiles my wife chose.
CXRAndy
Lincs
I use 5mm spacers to lift the pan off the tiles, apply silicon under the pan into the gap, remove spacers and let pan settle onto silicon. Clean up the excess splurge, leave to cure overnight.
Another advantage of a bead of silicon under the pan, is you tend not get that creak or grind when two porcelain materials touch each other
icowden
icowden
Surrey
That's not a bad idea. Bit late now though -it's stuck down. Bathrooms are on the list for re-doing anyway. Once we get second child off to Uni there might be a bit of money to be able to do it.
irw
Quadricyclist
Liverpool, UK
Sounds like you may have it now, but what you’re after is a flushcone…well found, that was one of the areas I was getting at with my earlier post. I learnt what they were when I started inheriting literally problem after problem with toilets at work (and we’ve got a lot of them). Seems the previous maintenance team either didn’t know, or didn’t care what they were either, and used silicon instead of/alongside perished ones!
https://www.toolstation.com/flushcone-pipe-connector/p28142
Make sure you clean out any evidence of silicon before inserting the new one!
icowden
icowden
Surrey
No evidence of silicon. I did discover that that epson flushcone fits a 38mm pipe and the pipe used by B&Q was 40mm thus had to go with the Fluidmaster internal flush connector (essentially the same thing but black and a bit more rubbery than the Epson). It was an absolute bar steward to get on the pipe due to limited access and limited length of pipe which had been cut really badly.
