Need help with my gear and bike
S
Hi.
Can you ride a bike?
If not: The trick is learning to balance while moving and it may sound odd but you will balance better going a bit faster than too slow.
Your elbow pads might be useful while you learn balancing.
Your levers on the bars control the gears as vickster (a lady) says. The one with the - to + marking will be the front gears and the numbered one will be the rear cogs. While you get confident riding you are probably best leaving them both in the middle cogs or slightly easier pedalling : slightly nearer the - sign and No 3 or 2.
When you are more comfortable start changing and seeing what happens. Nearer the + and higher numbers are more for flat roads, downhill, going faster. Near the - and low numbers are for climbing hills, sticky mud etc.
You need to think.of the front and back gears together to get the best out of them and to save damaging the cogs and chain: don't have the front all the way to - and the rear on 6, 7, or the front all the way to + and the rear on 1,2 as the chain will be running \ or / at an angle rather than. | as straight as possible between the front and rear cogs.
It all comes wirh a little practice and then you will be changing without even thinking about it.
As well as som .proper gloves, you should also think about simple toolkit: a pump- check it is the right valve type for your wheels, some patches to fix a puncture, some tyre levers to take off your tyre and a bike multitool or some Allen keys & spanners to fix and tighten bits up.
You could also get some spare inner tubes (look on your tyre sidewall for the correct size e.g. 26 x 1.95 - the tubes may have a range of e.g. 26 x 1.75 to 2.25 - these would be fine for 26 x 1.95 ) as they are always useful to have.
Later maybe buy some cables and brake pads ready for when your brakes or gears need servicing or start to get poor - that will be a long time so not something you need to worry about right now.
Most bike maintenance is pretty easy and plenty of videos on YouTube or the Park Tools website and the tools/kit can be bought online. It's good to learn as you say you are a distance from the bike shops.
Hello dear sir. Thank you so much for the very detailed reply. I am starting to learn to bike without anyone helping me. I must admit though when I start my ride I either get wobbly or lose my balance immediately. I somehow have a problem getting started with that. But when I'm on the road I'm kinda fine I can even stand up on the pedals but for some reason I get wobbly a lot of times. I don't know the proper posture and how to hold the handlebars properly maybe that's why my hands on the handle get shaky a lot. Also as it turns out I just found out there are many different bikes and it appears I'm using a mountain bike. I've been reading a lot of cycling forums and I don't know if the advice I read and also the proper posture on a cycling bike will work on a mountain bike as well. My balance sucks. I read that if you can get yourself to ride a bike first with 1 hand and then with no hands only then will you know you have proper balance. I can't even get off my bike properly. I'm still working on it and I'm really thankful you guys are helping out. Cheers to you.
Glasgow
Evening @snowskyflake97, this is a very good video for you to get you started.
