Need help!
fixolydian
I Just recently changed a puncture on my fixed gear, after replacing the wheel when I tightened the tracknut up on the drive side when it got halfway tight it just keeps turning, I can't fully tighten it, it just keeps going round. Have I threaded the axel or would a new tracknut do? Problem is I am not sure if I can remove it, will try later today.
I have cheap formula hubs,is it fixable or is the axel probably bust? Or time for a new better hub?
cheers!
Rhythm Thief
Ross on Wye
Sounds to me like you might have stripped the thread, although that would take quite a lot of torque to do. If you have, you'll need a new axle and new tracknuts. Have you tightened up the other side? It's possible that the whole axle is turning, rather than just the nut.
