The problem is that creaks and clicks on bikes tend to travel along the metalwork and usually only occur when you are riding both of which makes it hard to pinpoint the exact cause.
If you can't get the bike back to the shop then it's a matter of working through the likeliest causes first.
If it's new the shop should sort it out. Creaks when pedalling can originate from the saddle, seatpost, cranks, bottom bracket, pedals, handlebars/ stem- they can be tricky to track down.
A relatively simple one to check: does the creak occur when you are off the saddle? If not, it's probably your seatpost needing tightening or greasing.
Clearly the gears needed adjusting. It could have been all kinds of things but with a new bike and an in-experienced rider 9 times out of 10 it's just the gears.
