I don't know where they are made. They are ZEN that's a German company but I assume the factory is in China as most things are manufactured nowadays
The old bearings would spin freely after cleaning, with double seals in and without any grease but they wouldn't last too long if used dry.
For bicycle, I always thought bearings are bearings, some will last longer others will need more maintenance regrease. The speed they turn is negligible on the bike and I probably never notice it.
I'm just wondering if anyone has ever used standard low cost bearings which are a bit stiff when turning by hand but once installed it was fine after and got the expected results.
I don't want to use them if it's not going to work
When i got my Fulcrums, i immediately noticed a 'resistance' when freewheeling compared to my former wheelset that had done plenty of miles. I felt the new wheels would lose speed quite quickly and roll to a stop way before i felt i did previously.
IIRC the bearings in the Fulcrums were unbranded (i still have them in a bag, not that its relevent )
No doubt if i'd run them for a while they'd have freed up but impatience got the better of me and i brought some low friction sealed SKF jobbies. The difference was instant, but you're probably comparing £1 unbranded bearings with what were then maybe £6 SKF bearings.
Even with new standard SKF bearings, you can feel the resistance when turning them by hand, thats quite normal. It will probably free up with running.
With low friction sealed bearings you can feel the difference, they will run freer by hand straight from the box.
Whether that truly makes that much difference in the long term is debatable or perhaps negligable. In essense what i probably did was pay extra so i didnt have to wait for the originals to free up....but i'm ok with that, plus i now have higher quality bearings fitted.
BTW, there is a misconception that sealed bearings are maintenance free. They are in a sense but you can opt to maintain them. An example is my Veloce BB, i could feel a slight knock and roughness building up. They are of course sealed bearings but that doesnt stop you whipping the cups out, flipping one seal off the bearing, cleaning it out, regreasing and refitting the cup. This done, my BB is smooth again, no knock.
The same applies to any sealed bearings.
