Newbie advice needed re Marzocchi forks
Panter
Just call me Chris...
No, you'll be fine, twiddle away :biggrin:
The air is held in the top section under the top-up valve on the top of the fork.
Steve Austin
The Marmalade Kid
Mlehworld
Twiddle the black knob on the bottom of the right leg will do it a bit, but you might have to get into adjusting the air pressure in them.
A
ant_j
Thanks for the responses.
How do I out air into the forks,
or is this something that just get done at service?
Thanks again
Panter
You need to get a special shock pump, unfortunately.
They're not overly cheap but you can get them on eBay.
With that, you add the air through a schrader valve on the top of the fork (check your manual or online for the correct pressure first)
