So I got a second hand bike just as a beginner experience to try cycling in the city. Of course i didn't know how to test it for all the problems it might have. My question is, should the crank rotate freely when i do it by hand? For me it sounds pretty normal that i can adjust the crank and pedal position to be able to start the first step of biking. For some reason the pedal/crank seem stuck at a stationary position unless I start cycling with some force which is also hard as the pedal position is already down( 6 oclock) in the starting position. What could be the problem?
