Broadside
- Fleet, Hants
I have got some Superstar Icon wheels which i think are re-branded Novatec hubs. The wheels have about 7,000 miles on them and have been faultless until now.
The front catridge bearings seized so have been replaced and all is good again. The rear bearings then started screeching so i have replaced them and they are now fine too.
One problem remains though, the freehub quite often will not freewheel so the chain goes slack, and rolling the rear wherl forward while it’s off the ground makes the pedals rotate. I removed the freehub, removed and cleaned pawls and spring, rotated the freehub bearings and they are silky smooth. Upon refitting to the bike the freehub works as expected until i do up the retaining caps on the end of the axle, as soon as it is tightened the freehub gets stiff and then will not rotate. Am i doing somethhing wrong, should the end caps not be tightened? Or is the freehub knackered in some way and needs to be replaced? I’ve got the replacement bearings for it but heard it is a very fiddly and difficult job. Any conments of ideas welcome
