You only have/had once chance. It is a blind aluminium tapered spline on the crank and a steel spline on the axle. Once it has worked loose and was still pedaled whilst loose, chances are that it is ruined. Let's hope that isn't the case with yours.
Nevertheless, Octalink is rubbish, if it is ruined, replaced with square taper.
