Ningishzidda
Forget the law.
Did you put the motorist in hospital????
I
The only way to turn a bike without countersteer is to physically lean into the corner with your upper body & pull the bike into the lean that way. That's fine for fairly smooth turning but for short sharp turns it genrally leave you on the deck as you'll tend to overshoot & not balence the bike properly. You will counter steer even if you're unaware of it.
Nah, he was a nice guy (when he finally got out of the car and came to talk to me). A very relaxed conversation, I explained to him what he had to go and do (report this) and what I was going to do and what I expected the outcome to be. I was correct in that expectation so I'm sure the driver is happy to have a minor bump in his wing and no police action or need for the insurance companies to get involved.Forget the law.
Did you put the motorist in hospital????![]()
Fixed your post to represent reality as you see it.A modernbike will turn surprisingly quickly on a twitch of the bars without a lot of lean or counter steer and without you ending up on the deck,does not adhere to the laws of physics
Because of the non-dynamic mass in motorbikes you have to be taught to use counter steer as the motions required are much larger than your instincts will give. Counter steer becomes more important in higher speed sweeping corners because this is where it's hardest to change a motorbikes line.Counter steering as I was taught is to allow motor bikes to take sweeping bends.
Lean & counter steer are absolute requirements for turning a single track vehicle. The physics for this is well set & you can easily calculate the CoD offset required for any turn based on it's radius & your speed. By moving your centre of gravity about you can vary the amount of lean the bike needs a bit but it's not massive amounts.
The trouble with being further out is that you are putting yourself in the blind spot of a mirror check, I would like to think most drivers check the mirror for motorcyclists so would rather be in their field of vision. I hate filtering, barely bother at lights these days and most of my aggro with drivers is when I filter back in as the traffic pulls off.
You're wrong. read the first post.Am I wrong , but I am sure its illegal to over take on zig zag lines leading up to a crossing
Need to read earlier posts as this has already been discussed in some detailIts only illegal if you are operating your vehicle without due care, in a dangerous manner or being inconsiderate to other road users or pedestrians.
If the video evidence shows the cyclist was riding 'without due care', 'in a dangerous manner' and being 'inconsiderate' by overtaking a stationary line of cars on approach to a zebra crossing, then let justice be served.
