youngoldbloke
Anyone using one of these? Looks interesting.
Yes I bought the 378kwh extender for my Orbea Gain In Jan 2022. It now does NOT require the special bottle cage cradle Shown on the pictures on their website. It now comes with a cable on the bottom of the battery that goes straight into the charge port in the frame. So the volabike extender can be seated in any normal bottle cage. Handy for when bike being used without extender and you want two drinks bottles.Anyone using one of these? Looks interesting.
Still interested in how the extra was described as I thought import duty on rechargeable batteries was minimal.Yep it was around £480. Over 550 euros I recall. Yes I got the larger battery. The duty was paid to ups as the carrier before they released the delivery to my address. That’s the process. Was about £100 ish. Still adding all this up it’s better value than the standard marble battery and works better in parallel rather than just the charger for the main battery.I've just tried the site and it comes up with 449 euros, inc 77.93 euros VAT 'estimated for UK' - at today's exchange rate that would be around £380. So with the extra £100 that would be around £480. If you don't mind me asking is that roughly what yours cost? Was the extra £100 collected for import duty or UK VAT? A good saving on the Mahle anyway.
edit - just remembered you bought the 378 Wh one so my figures don't really applyStill interested in how the extra was described as I thought import duty on rechargeable batteries was minimal.
Yes it’s got a separate type of charger to the main bike charger. Weighs very little and compact. So it’s easy to carry. The gain of having the bigger parallel battery far out weighs the downside of carrying a little charger in my view.Looks interesting, but it comes with it's own charger, which (presumably) doesn't have the same plug as the bike 's own battery. That makes it unattractive for touring purposes, where the charger(s) need to be carried with you. If using the Mahle extender, however, I assume that has the same charger port as the bike.
Thanks - I didn't purchase due to the confusion regarding VAT. If I understand the government information correctly the import duty on Lithium batteries is 2%. So have you paid VAT twice? Pre Brexit the Volabike version would have been considerably cheaper than the Mahle one.Yep it was around £480. Over 550 euros I recall. Yes I got the larger battery. The duty was paid to ups as the carrier before they released the delivery to my address. That’s the process. Was about £100 ish. Still adding all this up it’s better value than the standard marble battery and works better in parallel rather than just the charger for the main battery.
Did the 144 km white horse challenge on Sunday 10th April. 1650m climb some excessive use of the Red zone on the steep sections. Still had 32% battery left. I’m over 95kg. Averaged just under 25kmh did it in just under 6 hours.
Volabike battery well worth the investment
although full marks for their support team for answering my email first thing the next working day!No, you can´t connect the extender when the main battery is low power.
Our extender can´t be used as a charger. It only can be used as parallel battery, so it has to be connected to the bike when the main battery is 100% charged.
Connecting the extender with the battery with low power, may block the battery because the high current introduced by the extender, so avoid this situation.
