painting an old garage floor
oxoman
It would fill the grooves in slightly. Takes longer to dry and paint. Personally wouldn't bother filling as it creates areas that can crack.
Tail End Charlie
Well, write it down boy ......
I painted my garage floor with resincoat - a two part paint which you mix and paint on and it fully cures after 24 hours. I bought two 5 litre pots and two 1 litre ones to do the job. Chose a lovely tangerine colour. You have to put a primer on first too.
Used one of the 1 litre cans first and it went down well. Then tried a 5 litre can - of course as soon as you mix it it is curing so you've got to paint like the clappers to get it down and it gets progressively harder as you get to the bottom of the can. At the end I was almost trowelling it on. Looked fantastic though, a bit like an abattoir admittedly.
I then covered most of it up with interlocking yoga mats and off-cuts of carpet to keep it warmer in the winter!
Chislenko
Slightly off tangent and I appreciate the OP's time constraints, but I have just tiled mine and wish I had done it years ago. The only problem with tiling is that garages have a built in slope to the front door which you can't really build up with screed as you would end up with a "step" Consequently you have to lay the tiles on a slope which is a more more tricky than a level surface.
How would paint take to textured concrete like this in my garage.
I'm guessing it would cover just fine but would be more work that a smooth floor. but a word of caution, painting cement leaves you with a painted surface, not a cement surface. a cement surface is more durable & probably easier to clean? if you ever want to resurface w/ new cement. you'd have to remove the paint. I wouldn't wildly suggest anyone paint cement. & yes, there are specific durable paints for cement such as "deck paints"
need to figure what is going on with this ice melt & figure out how to dispose of it. it may be decades old
so I moved this bag to the other side of the garage & put a plastic tarp under it. didn't seem to be leaking. I wonder if it was having some kind of chemical reaction thru the bag!?
I was able to rinse & sweep that spot & the paint seemed to stick & dry just fine. I guess I can keep the stuff, just maybe keep something under it? plastic? a square of plywood?
tried under one of the shelves, that was satisfying
Dadam
SW Leeds
Maybe there's a terminology difference but isn't your floor the same apart from the texture. My floor is concrete, i.e cement, sand, gravel; mixed, poured and presumably raked? Yours is smoother, so probably was rolled?
I admit it's not my area of expertise though. Some blokes came, levelled the ground, put boards round the area, shovelled some powder from bags into a mixer then poured it. :biggrin:
I'm just looking for a better covering that doesn't raise so much dust. Maybe those plastic tiles
november4
You can seal the cement floor simply with PVA glue and water, I have done that.
Not got around to painting it yet as that stopped the dust, and the garage is full now, but I've done before on another property with larger garage and it was very forgiving, great result and could park car on no problem, some sort of epoxy product
this house a lot of cement slabs, such as the back patio. not smooth. so whatever process (material & technique) was used on the garage floor, it was very different than the patio. it was built in 1966
I never noticed cement dust
maybe yours is dusty because it's new? have you tried cleaning it? maybe there's a dry dusty layer that developed after it dried & it just needs to be washed?
there are cement products for resurfacing, to make it smooth, if you don't like the surface
if you don't mind the texture, I might try washing it to remove the dust
a textured surface will certainly collect debris over time
notes to self: had grand plans to do more, but was occupied elsewhere. even after thorough drying I can see where the sections meet. gonna try to do larger sections to keep that to a minimum. don't want to do a 2nd coat. dunno if "blending" is worth the effort
