Painting with oils
Another attempt at 'controlling' the fluid oils. Starts with a grid of titanium white grouted into a masked off (and cut) canvas. All tbe primary and secondary colours are used and the brushstrokes are 'woven' in and out of the grid and each other. The process takes a while but is a nice effect. Sol Lewitt and Agnes Martin are two well known artists with a similar tendency...I need time and space for further adventures!
srw
It's a bit more complicated than that...
Just had a play with painting knives , it's supposed to be a rose :blink:
A Miss Goodbody's secret?
Reynard
Actually, that's the advantage of acrylics - they can be used either like oils (which is my preference) or like watercolours. Acrylics dry really quickly, but you can also mix the paint with various retarding gels to give them a longer dry time. Then it's easier to work wet-into-wet like you would with oils, but still fast-drying and non-stinky.
On the other hand, there are water-soluble oils on the market, and iirc, fast drying ones, but I've not tried them
Salar
A fish out of water
Gorllewin Cymru
And student quality acrylics are a lot cheaper than student quality oils if you are doing a large canvas.
I've also used household emulsions in the past for larger abstracts to match room colours and decor.
Reynard
That too... I use, in the main, the Daler Rowney System 3 and Liquitex Basic paints, along with the odd tube of the slightly pricier Liquitex Heavy Body. There are cheaper paints on the market, but they're a false economy as you don't get the coverage / opacity / colour of the better quality stuff. Anything like Reeves or supermarket own brand is fine for kiddies to muck about with, but very little else.
Back to oils, well oil crayons, the closest I get to oils :rolleyes:
Welsh sheep mart (market)
Great! I find them hard to use! On Pinterest, there is someone called 'Mary Blisser' (I think) who collates art as groups of people...not quite sure, but your piece reminds me of one of her 'pins'.
Salar
A fish out of water
Gorllewin Cymru
Found Mary Blisser, but couldn't open pin regarding crowds:scratch:
Sorted, found it.
