Boopop
Previously, on "Boopop's dealings with his Pashley":
Purchase and upgrades
New wheels required.
Well I've got the new wheels. It came with this shifter:
Truly awful. I couldn't get it to go in to the lowest gear consistently. I ride this bike at Critical Mass which can ride quite slowly (and rightly so), so the lowest gear is rather crucial. So, I bought it this shifter instead:
Problem solved, for a while at least. Now the lowest gear is slipping again (it started doing it before the new wheels were built too), it's driving me slightly potty. The wheel nuts are tight and so is the adjuster for the shifting. It survived one Critical Mass ride before the lowest gear started to slip again. I've seen some online say 5 speed is just a pain to set up right, and 3 speed is the one that's bombproof. I've seen others suggest the best shifter to use is this. Bizarrely it's only available in the US so I'd have to import it for £50. The similar shifter you can get in the UK only works with rotary hubs, my hub is an X-RD5 rather than an R(otary)X-RD5. Thanks for the info Sheldon Brown, RIP.
What do you all suggest I do, spend another hour or two fiddling in my garage bashing my head against the wall, or buy this shifter? Annoyingly the gear only slips when the bike is off the stand. Even when it's working the lowest gear is quite difficult to get to with the shifter. I expect to get lots of differing opinions, but I thought I'd ask just in case you all decide one way or the other with a strong majority!
Cheers
Cheers
