PC connection - advice appreciated
astrocan
Abingdon, Oxon
Our PC wil not connect to the tinternet either for web access or email.
Laptops which connect wirelessly are fine but the PC is plugged into the router with a cable.
I have checked the 'network connections' in control panel and there are two. One is called 1394 and all indications are that it seems to be functioning OK. I have tried to do a repair on this connection but got an error message along the lines that it was not set up for TCP/IP protocol. I have also tried going back to a resotre point without result.
The other connection is a LAN connection and there is a message saying that a cable is unplugged. I have plugged and unplugged the cable both ends and both ways round but, no dice. I have a recollection that on previous occasions when I have been prostrate at the alter of the back of the PC, the socket where this cable attaches had a flashing LED next to it. At the moment this light is not flashing, is this the problem? What does it mean? What do I need to fix?
Any advice, particularly that intended for a simpleton, would be greatly appreciated.
rusky
CC Addict
Hove
The 1394 connection is firewire. Ignore it!
Can you try the cable on another PC/another cable to try in the problem PC/a different port on the router??
rusky
CC Addict
Hove
If the LED on the LAN port isn't flashing or lit points it towards being a hardware problem.
astrocan
astrocan
Abingdon, Oxon
It looks like the network socket is US.
I am going to acquire and install a network card in a spare slot. The spec for the motherboard says it supports PCI 1.0 but all I can find are PCI 2.0 Does anyone know if this has a fair chance of working or am I wasting my time.
Motherboard is a NF4ST-A9 about five years old.
Cheers.
That's the pci express slots not the pci slots and pci express network cards were a lot less common than normal pci cards last time I checked and you have 3 pci to 2 pci-e 1 slots
