I have got the dust cap off, but the little nut on top of the adjuster seems to be an odd size and I do not have the size spanner, whatever it may be. The nearest I have is 11mill or 7/16th AF are just slightly too big and are slipping. I don't want to round the nut off.I had a pedal, think it was a Look delta one. Managed to drill a small hole through the end dust cap, which I could not remove and used a fine nozzled grease shryinge and squirted loads of grease through until it was coming out the other side.
Try an 0 (zero) BA spanner , that's halfway between 10-11 mmI have got the dust cap off, but the little nut on top of the adjuster seems to be an odd size and I do not have the size spanner, whatever it may be. The nearest I have is 11mill or 7/16th AF are just slightly too big and are slipping. I don't want to round the nut off.
0BA spanner ordered. I am going to try a few different approaches later on though.Try an 0 (zero) BA spanner , that's halfway between 10-11 mm
Thanks very much for that, 0BA arrived today and fitted like a glove. I checked another set of pedals and they are the same fit, but yet another pair are bang on 7/16th's.Try an 0 (zero) BA spanner , that's halfway between 10-11 mm
