Twanger
- Crystal Palace, London
I have been trying to work out how to put toeclips on Brompton pedals. How do you lot deal with the issue?
.Crankarm said:SPDs on mine. I haven't looked back.
SavageHoutkop said:I haven't yet. I was looking at PowerGrips - but you need to use really short screws to not mess up the folding apparently. I did a google and found someone had done it and posted some pictures to prove it. I suspect more holes might have been needed than the pedal has, so perhaps some drilling was needed as well. See here.
Failing that, it seems you get SPDs with a pull off pedal to replace the folding one.
I'm not too eager to go down that path though, as it will completely invalidate all my existing footwear....
SavageHoutkop said:The reason I want something on my pedals is mainly better grip. Currently in the wet my feet tend to slip off the pedals, especially when wearing my waterproof trainers. So, if my current metal pedals are bad for grip, how much worse would a smaller SPD pedal be?
purplepolly said:Can you fit any kind of pedal to them? MKS do several quick release pedals that will take toeclips, I've got two different pairs on my folders.
