Peugeot carbolite rear derailer
Rebuild1961
Glenolden,pa
Hello. I have been off this site for some time. A year ago I started a complete rest on a carbolite. I cannot remember how to put the rear derailler back on the dropout. Any help, tks.
The threaded bolt at the top of the mech screws into the gear hanger below the dropout.
Rebuild1961
Rebuild1961
Glenolden,pa
Ok thank you. If I remember correctly, I had to remove the cage before and after the process. The threaded piece does not move freely so I have to manually screw the unit in place?
Rebuild1961
Rebuild1961
Glenolden,pa
Just another pic. It stops short, the black ring tip catches on the dropout and there is still threads exposed leaving me short a few turns
It should turn with an Allen key. Just line it up carefully so you don't cross thread and use the long end of the Allen key with minimal pressure till it is fully home and then tighten.
Rebuild1961
Rebuild1961
Glenolden,pa
Ok I will try an allen key. I do see the shape inside the screw head. I basically forgot what I did last year. I had 2 1990's bmx bike come my way and got both of them done ground up resto. Thanks again.
raleighnut
It's the 'F' stop that's getting in the way. You need to move that rearwards as you engage the mounting bolt.
Rebuild1961
Rebuild1961
Glenolden,pa
Got it. Now I can move on to resto a early Super Record that came from All Star Cycles in California. Found it on EBay 80 bucks 40 for shipping. Got all
Raliegh hardware. It was kept indoors so not a hard cleanup.
