PHD Sleeping Bag Drishell vs. M1 vs. Mx
thinkpurple
Hello altogether,
I am looking into getting a Design-Your-Own-bag from PHD. Lots of choices to be made...
I would love to hear about your experiences/opinions about certain options:
1. M1 vs Drishell outer fabric: How about 1.1 breathability, 1.2 water-resistance, 1.3 durance, 1.4 pack size?
2. Mx vs M1 inner fabric: 2.1 Does either of them feel nicer? 2.2 Is Mx significantly less durable?
3. Would you opt for a mummy hood? It adds some extra weight and I wonder if a beanie would also do the job when I have a collar.
Thanks a lot for your advice!!
Midlands
Having just completed a tour where i started out and it was 20+ at night at the start and below zero at night at the finish i think it is very difficult to come up with a single bag that suits all conditions - if i was starting again and spending that sort of money i would be looking at a bag system - although having looked at PHDs site lots of times in the past I havnt come any conclusion what i would buy
Fabric wise I would want something reasonably durable - cycle touring packing up every day takes its toll on a bag - as to the the mummy hood - I hate them but would not have a bag without one - a decent beanie is pretty good but when it is decently cold nothing really substitutes for being able to batten down the hatches and the continuity of the mummy hood.
When touring and sleeping in a tent, a good's night sleep is absolutely essential, IMO. A bad night's sleep is a recipe for a bad day on the saddle.
I'd suggest a good airbed, like the exped 7, which prevents the cold coming up from the ground and if you're in a 2-3 season sleeping bag you should be OK, depending, of course, when you're touring.
Light silk/merino wool base layer could be taken (or experimented on beforehand) as it doesn't take too much space. A small inflatable pillow is also recommended, and a beanie if it's particularly cold.
andrew_s
Gloucester
I use a Minim 300, M1 throughout, full zip, a sale special from a few years back.
Whilst, when stuffing the bag, I sometimes notice a bit of dampness round the foot area where the bag brushes against the tent inner, I've never noticed any loss of warmth as a result. The main advantage of drishell would be to fend off that kicked over tea mug, or if you anticipate non-tent use, under a tarp or similar.
As far as the feel of the inner material is concerned, it doesn't matter, because you ought to be either using a silk liner, or wearing a base layer set, purely from the need to keep the bag clean.
I think if I was to re-order via design my own, the only thing I'd change would be to get a bit extra down in the top couple of front baffles. It's fine when the hood drawcord is pulled tight (ish), but a bit thin when the bag is unzipped and I'm using it as a quilt.
