Pleeeez Recommend Me Best Ladies Gloves For Pain Relief
I have eventually managed to get my wife away from her old straight bar ladies Raleigh, with twist grip gears and on to a modern drop bar gravel bike. At 65, she has the beginnings of arthritis in her hands and was getting occasional carpal tunnel and wrist pain from the old bike. My thoughts were that more hand positions, combined with easier gear changing might help to make life more comfortable.
We’ve had a few local rides of 9, 11 & 13 miles and she is finding things easier on the new bike, however she’s not entirely pain free, which might be partly down to the thin padded gloves she’s currently using.
Has anyone alleviated similar problems with really good padded gel (or other padding) cycling gloves and if so, any recommendations would be appreciated.
TIA
ianrauk
Tattooed Beat Messiah
Rides Ti2
Maybe a good idea to get some handlebar gel inserts for underneath the bartape.
Reynard
Lady rider here, most rides in the 5 to 15 mile range. :hello: I'd start with the cheapest options, which is a) to raise the bars and b) to drop the pressure a bit in the front tyre. You could also c) flip the stem.
For me, the biggest difference between hybrid / MTB and road bike, is that the former, you're sitting very upright, and on the latter, you're definitely more forward. I found the road bike became less uncomfortable once I built up better core strength. But it's largely about getting the weight distribution right between front and rear though, to prevent discomfort in all the assorted contact points with the bike.
As for gloves, I found that the more padding I had, the less feel and dexterity I ended up with. I prefer a thinner glove. I think it's just too personal really, just like shorts and saddles.
P.S. there's absolutely nothing wrong with riding a bog standard MTB or hybrid. A nice easy fix to make those more ergonomic is to swap the twist shifters for trigger pods, and fit some nice Ergon grips, which support your hands and also give you the option of bar ends as well. I have the GP2 versions on two of my bikes and would thoroughly recommend them. Ebay is your friend here, if you don't fancy paying through the nose.
wafter
Oxford
Great work :smile:
Can't help with the gloves but to build on what's already been said, look at mass distribution between the saddle and bars as well as general fit.
Having the saddle too far forward can increase load on the hands and cause issues, as can having the bars too low and too far forward.
As @Reynard says you can flip the stem to increase bar height (stack), while reach can be shortened by fitting a shorter stem.
:smile:
G-Zero
G-Zero
I’ve passed that all on, thanks.
Once a Wheeler
…always a wheeler
Try these sheepskin gloves:
Available here; a bit pricey (£65.00) but they might do the trick. I had lasting problems with gloves for touring and training until I discovered sheepskin which worked wonders. The natural fleece keeps them padded and warm and also remains reasonably cool in warmer weather. Well worth a try. For a trial you could buy a pair of cheap sheepskin gloves and just cut off the ends of the fingers and any over-lengthy cuffs. Good luck.
