Polarity of battery packs on LED ('Cree type') lights
KneesUp
I think the battery pack on my generic retina-burner light with Cree LED has died. However before I order a replacement, I'd like to check the light works with a universal power supply I have - but I don't know if they are positive tip or negative tip. Don't suppose anyone knows? Ta.
Wobblers
Euthermic
Minkowski Space
After a quick check with the multimeter on my Magicshine battery pack, the centre pin is positive, the outside is negative. If your light takes a 7.4 V Li-ion battery pack (most of the Chinese lights do) it should be the same - I've got a battery pack that came from one of those cheap lights (which lasted all of one hour!) which will run my Magicshine quite happily.
If your power supply's a bench power supply, with adjustable voltage, I'd wind the output down to zero before connecting it and then increase the voltage slowly whilst checking that the current doesn't rise too fast: anything more than 1-2 Amps is probably too much.
