Drago
- Suburban Poshshire
I keep one front light on solid, because on unlit country roads because I simply need it to see by. The 2nd light takes care of flashing duties.
.I had a front light failure yesterday, put in new batteries in the morning (and didn't use it) and so was expecting it to work in the evening - but the light wouldn't stay on for more than 30 seconds - couldn't find the backup light. Luckily I was on a cycle path and so turned the light on for it's 30 second burst when I met other cyclists or in really dark bits. It was a reminder to me to have the second light. Of course this morning I find I had the light all along - but in the wrong pocket!!!Last winter I rode home from work along my usual unlit fast b-roads.
Getting to a junction I observed rather unhappily that my rear light had stopped working over a bump somewhere along that road.
There had been loads of cars passing me safely and I think the reflectives on my gear had made me visible.
Day off luckily - though I still need to investigate the light - I suspect that some of the batteries had lost some of their charge (hopefully rather than the light is not working properly).ha... I was like that with my bike tool/tyre levers/patches today - looking all over the house for them yet they were nestling in a pocket in my jacket, right where they should be. At least with the front light you know if it's not working ! Safe ride home.
Pedal Reflectors - yes, you need these as well! It would be interesting to see how these cold be fitted to modern racing pedals.... Anyway, four of them are required and they should be amber in colour and marked BS6102/2 and positioned so that one can be clearly visible to the front and the rear of each pedal - does this mean that to be legal a tandem only has to have one reflector on each pedal?
Good pointsWhich technically makes reumbents illegal as you cannot meet the "clearly visible to the front and rear" due to the vertical axis of the pedal when in use.
It also in technical terms precludes the use of panniers if these obstruct the view of the pedal reflector from the rear
Iirc you can have the naffest legal light and have a lighthouse beacon and be legal, as long as its not blinding other road users.There is a fine line between breaking the law and not
Most of my bike lights are illegal as they are too bright but I use them to make sure I can be seen
All my bikes and trikes have legal lighting ......... Shame you can't see them as the backup system overpowers them
