rebelpeter
I am sure this post will create a lot of varied opinions but I have been riding for about 60 years now and i have found for the past few years that instead of keeping into the curb, I now cycle about one third the distance out from the curb to the centre of the road, I do this as seems to me if you try to keep in too close cars will try to pass you and for some reason they think they need to pass you inside the middle white line often coming very close brushing your sleeve is not that uncommon , but if I ride further out seems they see then they can not sqeeze past you without going over the line so they then pass much wider and well over the line, try it and your see them pass you a lot wider than if you ride closer into the curb.
