possible to use a from MTB disc brake wheel for a fixed conversion?
montage
God Almighty
Bethlehem
I swear I have seen it on this very forum, but cannot find the thread, but is it possible to simply remove the disc brake fro ma front mtb wheel and bolt on a cog?...therefore creating a fixed wheel?
What else would need to be done to it?
EDIT: Done some more research so some more questions:
1. Will a bolt on cassette cog fit to any brake disc mount? If not then how can I check these are compatible?
2. Can the brake disc mount be moved along the hub with spacers to get a better chainline?
3. What is the standard spacing of a front mtb hub and the rear of an "older" steel bike?....if the modern spacings of the mtb hubs are more than the spacings of the newer bikes then am I knackered?
4. What bolt on cassette cogs can I use? Or is drilling one going to be cheaper
Anything I haven't thought about?
montage
montage
God Almighty
Bethlehem
https://www.cyclechat.net/
found the thread!
RedBike
Beside the road
They're not cassette cogs or track cogs. They're fixed wheel sprockets pre-drilled with the correct pattern for a 6bolt hub.
http://cgi.ebay.co.uk/fixed-gear-co...sure_cycling_bikeparts_SR?hash=item19bae75851
Yes, you put a few washers behind the sprocket to re-position it.
A front hub is 100mm, I know that older 7speed MTBs used to have 130mm spacing and its possible that a 5speed MTB was only 120/126mm spacing, although i've never owned one. Modern hubs are 135mm.
If the frame is steel then you can probably spring it in/out to fit either a new MTB hub or a track hub.
I've forgotten where I purchased mine from, somewhere off ebay. It was about £15, so no its not really much cheaper to drill your own.
montage
montage
God Almighty
Bethlehem
Thanks for the help redbike - perhaps I should have mentioned that I plan to put this onto a road frame though? Not a mtb frame teeheee
