One that fits your frameSo replace derailleur and hanger ? It's tiagra 10 speed. Any specific hanger which is best? Thanks 👍
Is the derailleur actually broken?
Mainly used for integral steel hangers. Alu ones will break ( as designed) if you bend them too many times or too hard. Integral aluminium hangers are a design flaw.Would you actually replace or just bend back into shape, I have in the past with no problems.
Let's face it when you use one of the bespoke hanger alignment tools they exert a fair bit of force on the hanger so they must be designed with some strength in mind.
If you don't have a alignment tool, then a new hanger is the cheaper and safer option.Would you actually replace or just bend back into shape, I have in the past with no problems.
Even a new hanger needs aligningIf you don't have a alignment tool, then a new hanger is the cheaper and safer option.
I have had one straightened in the past but it wasn't far out of wonk, Frame maker had no idea what hanger was on it, and certainly no spares kicking around.
the vast majority you can simply attach and they will be within such a tolerance that you can index your derailleur with no issue at all.Even a new hanger needs aligning
