Pre-painting stain coverage - help!
asterix
Comrade Member
Limoges or York
Paint it with white gloss first, then your normal colour in emulsion. I had to do that when my roof leaked last year and stained my bathroom ceiling. Works a treat
Yes, I did the same on a decorating job for a friend. They were going to buy some pricey special stuff. Two years on we are still friends so I guess it worked.
ps Never mind @rich p - what does he know?:whistle:
screenman
I was always told emulsion over PVA is a no go. Which is why I use a blocker, proper product for a proper job, no point spoiling the barrel.
I always used this stuff. Methylated spirit clean up - so it was a dandy aroma in the place! There is an acrylic version too - 'Bullseye' I think?. All their products I found pretty good. Heavily pigmented, it can be prepped to a fine finish, to receive a top coat. Ideal for MDF too. Disposable brush saves cleaning up too. Beautifully quick-drying.
A water-based polymer adhesive. Can arrive in various strengths and formulations but generally, wood glue, paper glue for craft etc, constructors adhesive, a 'primer' for evening out the suction of a substrate blah blah. The magic component!. I used to use it as a carrier for acrylic artists colours, and cover rooms in many thin coats of a 'glaze' to give an amazing density to the colour(s) one used. Interesting stuff, and dries clear usually.
PolyVinylAcetate - I think.
screenman
What's PVA?
Just asking, not looking for an argument:angel::smile:
It would be quicker to use Google. It has many great uses. I would not use it to seal a wall before painting though, but as others have said it has worked for them.
rbreid
Old git on old bikes
Artists fixative spray. Worked for me when my kids decided that A4 paper was too small to let their artistic talents shine through in their wax crayon work:wacko::wacko::wacko:
asterix
Comrade Member
Limoges or York
It's good for stabilising loose plaster work and dusty concrete floors. I use it quite a lot for butt-jointing plasterboard at the moment using a narrow strip of plasterboard to cover the join. It gives a very strong joint indeed. Also stick polystyrene insulation to plasterboard with it, very effectively.
Wonderful stuff! Can't find it in France..
