A galvanic reaction between the carbon (or resin) and aluminium sounds a bit odd. Got any more info on it?
I found this one. It was an interesting case in that the seatpost was an alu tube wrapped in carbon. The corrosion happened between the carbon wrap and alu. I had to remove it by sawing off the post and then sawing vertically through the aluminium bit. I can't remember what bike it was in, whether it was a carbon or alu frame, but the problem was between the carbon and alu in the post itself.
Edit: I have changed my mind about his seatpost. This problem, I now remember was pure oxidation, because the post had swelled to the point where it could not be removed and the white is a dead give-away.
The Cervelo problem was pure galvanic. It just had the look. Metal that had disappeared, holes and jagged edges. The insert on those BBs is probably 3 or 4mm thick, so the corrosion required to eat right through that was pretty severe.
