Crackle said:It's still not you at fault though. That was clear bad driving, the only thing you can do is learn to anticipate it and as you say that was a valuable lesson - good footage too.
domtyler said:He was only not at fault 'technically' or legally. But as cntl could have prevented the behaviour through his own actions there must surely be some type of blame or fault? In much the same way that someone going up the inside of a large left turning lorry is not technically at fault when it turns left without properly looking and crushes the cyclist to death.
Terminator said:Im not changing my riding just to please people on this forum.I haven't been cycle commuting for five minutes i've been cycle commuting for 27 years.
If I had cause for concern with regular incidents then yes I would but I dont so nitto.
With the regular posters who seem to regularly post 'incidents' not being me apart from a collision in Feb 2006 and The mini rounderbout incident (where I fell off doing it correctly like a good little cyclist) then there you have it.
Ok fair enough perhaps people who post regular incidents are unlucky and I would not wish this sort of stuff.I've been there.I do actually think in all the years i've been cycling my record is very good.(Touchwood) although Domtyler will probably say 2 ped collisions 15 years apart is appaling.He did last time.
I blocked a boy racer at Mile End the other day and I was as worried as hell.I'd rather fly onto the pavement then go through that again.My bike isn't fitted with a device to tell me how much they had been drinking...(or smoking) (Not yet)
Last time I changed the way I ride I fell off due to so called advice.
magnatom said:No-one here is telling anyone else how to cycle (ok maybe cab is ).
Cab said:I'm telling people how they should cycle, not how they must.
Cab said:Good for you.
How close are you comfortable with? I mean, lets say you're cycling along a road, and cars are coming past you. Whats the minimum distance between your right elbow and the cars that you're comfortable with?
It all depends on what you mean by 'incident'. Most of what I complain of here is other cyclists, occasionally motorists getting shirty with me because I've taken the correct road position, but you'll rarely see me complaining about close overtaking because such a thing rarely happens. And it rarely happens because, for the most part, I ride in primary position wherever appropriate. If motorists frequently overtook me too closely I'd complain about that, which is why I've now asked you how close you're happy with.
Try riding in primary. You muse be curious as to why so many expert sources (such as, say, Cyclecraft, Effective Cycling, etc.) advise that the right way to cycle is to use Primary where appropriate (or the similar premis, 'vehicular cycling)? You must surely wonder why so many otherwise sensible people are suggesting to you that primary is the way to go?
tdr1nka said:That really ought to have been 'might' instead of 'should', it is still every cyclists right to be squished if they want .
