Hi all, I need help diagnosing a problem on my 2016 Carrera Subway one with 24 gears
I am able to shift all the gears on the cassette with no issues.
I can shift DOWN from gears 2 to 1 on the crankset, but when I try to shift UP the chain just rubs against the front derailleur and I have to hold the shift paddle in to force it to change, I cannot shift up to gear 3 at all, the shift paddle won't even depress fully in when I try to select 3.
also the gear indicater for my crank set does not change when I change gears, the indicator is stuck on '2'
I will reply if you need more info
thanks
thanks
