I've had an ongoing shift problem when manouvring between the large and small chain ring on my compact double.
I took it to the shop and they reset the front mech position using the limiter screws and it then shifted fine on the workstand. Back on the road though it's a different story.
The issues are thus:
Small to Large - taking a good few revolutions to pick up. Sometimes the chain will really struggle to get up there, and often when it does, it will tumble over the other side.
Large to Small - frequently, and especially at low speed the chain really doesn't want to leave the big ring.
I've used the barrel adjuster to loosen the cable and make sure the mech cage is central over the chain when in the big ring, but the problems persist.
Does this seem like:
a) I have no idea what I'm doing and it just needs someone to set up the mech properly?
b) It's possibly time for a new cable?
c) Something else?
Cheers for any advice.
c) Something else?
