Pumps for tubeless tyres
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Have you used soapy water around the rim when seating the tyre? Makes a big difference to how easy it is.
Jody
Stubborn git
I did wonder about that. What output (if that’s the right word)? They seem to quote litres, which I assume means litres of air/minute?
I use a compressor also but using an air duster attachment with the valve core removed. Quoted litres is only the capacity of the cylinder and not the flow rate.
lazyfatgit
Lawrence, NSW
I also use a compressor. After watching a friend struggle with a reservoir type pump getting road tyres to bead I decided it was too much faff.
The compressor is a fairly basic one, not bottom of the range but one or two models up so it’s got a regulator and gauge and can power some low volume tools too.
Fortunately my experience with tubeless so far has been pretty good. After a messy start there’s been no issues with the road bike. Tubeless on the mtb was really easy to do with the compressor. Not sure about filling that tire volume even with a booster pump.
U
User482
I just use a CO2 cartridge. It's not a problem often enough to justify a fancy pump.
Jody
Stubborn git
You aren't meant to use CO2 with tubeless sealant as it causes it to congeal.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
With the original UST standard for tubeless you can reinflate when riding using a bog standard pump, does not even need to be a track pump. Think road tubeless could learn from that as reseating in the wild is the main worry.
lazyfatgit
Lawrence, NSW
There’s no way I’ll be able to reseat my road bike tyre/rim combo (Schwalbe pro one on CZero rims) in the wild. It will definitely require a tube to be fitted if there’s a puncture that doesn’t seal.
When I topped up sealant after 3months the tyres didn’t stay beaded. Popped off in random places as tyre was deflating.
