....puncture...new tyre ?
Dzzi
Hi
Heard the dreaded hiss of doom on Saturday but as luck would have it i was literally 40 yards from my front door. When i stopped i quickly found the source of the hissing an odd bit of damage, a small (1-2mm) but pretty obvious divot out of the tyre (Specialised Armadillo) had been sort of dug out (sorry should have taken a picutre).
Anyway the air loss was so small that by the time i had got the bike into the back garden had a drink etc i needed to deflate it to effect a repair.
The odd thing (and maybe its not that odd but ive only had 3 punctures in these tyres in around 800 miles of cycling) is that the inner tube was hardly marked, really couldn't detect a hole as such. Anyhow i put a patch over it, rode 40k on it yesterday no issue.
I assume the tyre is ok but clearly now not quite perfect, just wondering if people would bother to replace it at around 30 notes....
tyred
Ireland
Unless the tyre carcass is damaged - you should feel a bulge at the weak spot when it's pumped up or the hole is big enough for the tube to start coming out, I would leave it.
