Looks good, any specific reason for the negative headstock/reversed fork?
Well, on on normal bike, when you are stationary and let go of the handlebars, they tend to turn fully to one side. If you make the rake the 'wrong ' way round, with say 4 cm trail, it straightens the steering to point forward. This helps stabilize the bike. When you are riding along and the bike leans to one side, it tends to steer the way you are leaning, which makes the bike sit up again. It makes it more stable than it should be for quite a long, low bike, with little wheels. So when the rake is in the opposite direction, it helps the bike balance better. If you don't believe me look at this
View: https://youtu.be/5MQ7qDzfENo
My homemade skateboard uses the same principle.
