Question on Shimano Alfine, 11 speed
novetan
I just purchase a folding bike Tern Verge using Shimano Alfine, 11 spd. That's all the spec tells me. I tried to google but only to be told its a 400% gearing ratio, something like that which I don't understand. Anyone knows how's the spacing of the teeth?
Tks
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
Here you go Alfine ratios
N
novetan
Tks Andy.
How does the various gear ratio translate to no. of teeth? I don't understand gear ratio. Perhaps you may want to give an example for gear ratio 1 listed as 0.527 means what?
Tks so much.
Andy_R
County Durham
It depends on the size of sprocket being run, so if using 20 tooth sprocket, it would be equivalent of
38.0 lowest gear
29.4
26.0
22.8
20.1
17.6
15.5
13.7
12.0
10.6
9.3 highest gear
Worked out by dividing number of teeth on sprocket by ratio
N
novetan
38.0 lowest gear
29.4
26.0
22.8
20.1
17.6
15.5
13.7
12.0
10.6
9.3 highest gear
Thanks Andy so much.
Using the 2 lowest gear as example, 38-29.4 = 8.6, I suppose shld be either 8 or 9 teeth, is that correct?
Andy_R
County Durham
Not quite. You need to count the teeth on the sprocket on the Alfine hub and divide by the ratio; for example a 20 tooth sprocket on ratio 1 (the lowest gear) gives this: 20/0.527=38 so a 20 tooth sprocket and gear 1 on that hub would be the equivalent of a 38 tooth sprocket on a cassette. Using the same 20 tooth sprocket on the next gear you get the equivalent of 29.4 tooth sprocket on a cassette. Obviously there is no such thing as .4 of a tooth so I would round to the nearest whole number. Based on that, you would get the following cassette: 9-11-12-14-16-18-20-23-26-29-38
N
novetan
Tks again Andy.
Where do you derive 20 tooth sprocket? Is it native (or default) for Shimano Alfine 11 spd or just an example?
Tks again
Andy_R
County Durham
Its just an example. The Alfine has options for 18, 20, 21, 22, or 23T sprockets
