Sam Kennedy said:
I took both my wheels off (had to pick glass out of tyres
) and after putting my back wheel back on, the brakes were pushed against the side of the rim.
I pushed the brake blocks with my hand, and the wheel bent/flexed in the direction I pushed it, is this normal or do I have to tighten the quick release a bit more?
All depends on how hard you pushed the blocks really?
I suspect what has happened is that the calipers have moved off centre.
But firstly make sure that the wheel is fitted centrally in the frame. Look at the gap between the tyre and the frame by the rear triangle/seat tube/bottom bracket.
Once your are happy that the wheel is central, realign the calipers. Its a bit hit and miss the first few times you do it, but you'll soon get it right.
Then operate the brakes, the blocks should strike the rim evenly. If one side hits the rim first, then just tweak the caliper across a fraction.
On the higher end spec calipers there is a tiny grub screw that you can adjust to align the blocks, but IMHO just tweaking the whole lot with your hand is quicker!
As for if the Q/R is to loose, it should be adjusted so that when you move the arm over centre to tighten it, there should be small amount of resistance.
If all the above is ok, then grab the tyre and try and move the wheel from side to side, it could be that there may be some play in the cones?
