- the post-brexit wasteland
having previously used a combination of pliers and bad language to remove the inserts from cartridge brakes, the stubbornness of the campag brake cartridges forced me to rethink.
solution? a tiny flat-head screwdriver (like you get in a watch-maker's set) used gently under the old cartridge at the open end will prise the cartridge out with remarkable ease. the little screwdriver has earned itself an upgrade to the bike toolkit…
and one more tip, if you buy new cartridges that have a little bolt on the back, remove the bolt immediately (unless installed on a fixed-wheel bike) as they inevitably either seize or strip the head bolt, making brake pad changes very difficult…
