Illaveago
- Chippenham,Wiltshire.
Raleigh 531 Granada. These are the words that drew my attention to this cycle advertised on a well known auction site. Well, along with the low price and the colour, what looked like Kingfisher blue. I am a sucker for pretty colours. I put it on my watch list whilst I thought of reasons why I didn't need another cycle.
Nagging doubts were soon filed away in the cobweb part of my brain whilst I thought of the positives .
It looked complete with all of the components, centre pull brakes, 2 wheels, handlebars, double clanger. What more do you need ?
I did a bit of research on the web to find out a bit more about the cycle. The Granada was made for 2 years from 1986/7, Reynolds 531 butted frame tubes, 27inch or 700 alloy wheels.
Nagging doubts managed to escape from the dark recesses of my brain. Buyer collects ? Not too far away, I could fit in a trip to the seaside at the same time .
What size frame is it? 21, 22, 25? The details were a bit sparse, but by using the head badge I calculated that it was a 22 inch frame. It turned out to be 21.
On the plus side it was still cheap and it had all of the components.
I had set a limit as to what I was going to spend. This seems to have a lower maximum limit than the eventual higher limit which I tend to end up spending.
The final day came. I put in a bid and was out bid immediately. I raised my bid and was leading for a while until I was outbid again. In the last few minutes I raised my bid but had a higher one in reserve just in case.
Outbid ! But I hit the higher bid just in time I won!
I hit the pay now button . Now to arrange collection!
I contacted the seller, he seemed very helpful and so we arranged a date and time.
The journey turned out to be a lot further and took longer than planned due to the insistence of my brother using his satnav. If I could have reached it, it would have gone out of the window .
It must have been set on the most windy route possible.
I eventually arrived at the destination. The bike looked different to how it appeared in the pictures.
I have discovered that things look a lot better in pictures than they do in the flesh.
A quick look around the bike. 27inch wheels, good. In need of a good clean though! 531 frame, good! Phew it felt heavy!
I didn't realize it weighs around 27 lbs. The frame looked a bit smaller than I imagined.
I undid the front wheel and loaded the bike into the back of my car. I said thanks to the seller and set off home determined not to listen to the satnav. The journey had worn me out so no trip to the seaside, I wanted to clean and get the bike rideable as soon as possible .
By using the Force I got home far quicker and discovered some very pretty countryside.
I must add that my wife had no part in this transaction as she was away in France at the time.
Once I had removed the bike from my car I set about cleaning it up to get it working. The good thing about this hot weather is that things soon dry off. The chain was very rusty and stiff so I removed it and let it soak in some old engine oil. I removed the wheels and replaced them with a pair from my other bike for the time being.
The seat tube needed a bit of sorting out. Someone in the past had fitted a seat post which was too small and had bent the clamp mounting. A bit of hammering with the steel post provided and some filing soon sorted it. I borrowed a seat and post from another bike.
I cleaned off the chain which had responded well to treatment and fitted it. Now for a test ride!
I was very surprised and happy. It rode really well, it fitted me perfectly despite being a smaller frame than my other bikes. The top tube is longer. The short test ride became 5 miles as I was enjoying it. The ride was really smooth even over the rough road surface. The only problems encountered was that the front brake didn't ! Well not very well and an annoying creak from the bottom bracket.
I have discovered that things look a lot better in pictures than they do in the flesh.A quick look around the bike. 27inch wheels, good. In need of a good clean though! 531 frame, good! Phew it felt heavy!
. Not heard the saying "double clanger" for 40 years lol. Made my day
