Quick update of the lenton, pulled the rear hub apart cleaned and rebuilt, fitted new bearings to bottom bracket seemed great until i removed the crank arms and then axle would hardly turn bearings where not to bad but grease had turned to a sort of solid muck.
Fitted new cables,hand grips, led bulbs, new bearings in head set,front wheel (same bearings as bottom brackets big bearings for a front wheel) and pedal bearings and of course brake blocks, greased seat post and applied proofide to saddle.
took it out for first long madin run and rides great really comfortable dont know if its the heavy 26 inch steel wheels or the forks but very nice feel to it hard to describe but feels like you could take your hands of the handlebars hit a bump in the road and not have to worry.
Only down side of the lenton i took it for a 52 mile run and usually on a solo run with little or no wind and traffic it normally takes me appox 3 hours with the lenton it took just over 4 hours and i was pushing quite hard? Perhaps down to the dynamo hub or the weight of the bike but its not a quick bike.
Only things i may change if i can source 40/32 spoke alloy rims and fit more modern twin pivot brakes plus i will look on e bay for another rear light as it would be great to have a matching pair on it. Led bulbs are not shown in the picture as i only received them this after noon
