razors
tyred
Ireland
I've tried some of the three and four blade razors and seen no advantage whatsoever.
I prefer my old Gilette G2 but replacement blades are getting difficult to find. Tesco's do a version but they go blunt very quickly. I ended up buying a job lot of genuine gillette ones on ebay for a fiver.
I would love to try a cut throat but would probably do myself serious injury...
mr Mag00
rising member
Deepest Dorset
I guess the need to shave is is nothing to do with additives, who knows, if they do it with food? also the more you shave the more you need to shave in my experience, like legs?
I shave very infrequently and find the mach series they only razors that dont block with the bristles. i use green people mens range and find it excellent. i do keep meaning to buy a badger brush, fond memories of play with my dads and lather soap all over my face as a kid :tired:
i would love to go for a proper shave at a barbers one day, but would be nervous as hell
ASC1951
Yorkshire
I agree with Chap about shaving soap - aerosol shaving foam truly is the Devil's Nose Bubbles.
The most important factor in a good shave is giving the bristles long enough in warm water to soften the keratin. In Chap's case, that would be done by an old gentleman in a green waistcoat leaving a hot damp towelette over your face for ten minutes while you muse on Wafflycat's plaits.
I do it by shaving in the shower, just before the final Rinse Cycle. If you run one of those shaving soap sticks over your chin, you and the dead badger can froth it up in situ. One disposable razor lasts me at least a month.
threebikesmcginty
Corn Fed Hick...
...on the slake
I still like my old GII, Mozzer do a reasonably priced own brand - it's probably all made in the same factory anyway.
I once read that 'a good lather is half the shave' - it's true! :tired:
Hover Fly
He, him, his
阿爾弗斯頓
chap said:
... get yourself down to London posthaste
Regards,
Chap
p.s. If you are in the unfortunate situation where travelling to the great city is not presently feasible, then you can order online.
They do have shops outside the M25, I used to get all the shaving requisites I needed in the local chemist.
I use one of the new Phillips electric razors with the Nivea re-fill.
It's fantastic. Nice to have a good shave without tearing my skin apart.
ChrisKH
Essex
I find the multiple blade types are sharper. But not for very long.
If anyone finds a razor that can also safely shave my ears at the same time, please let me know. :tired:
threebikesmcginty
Corn Fed Hick...
...on the slake
Uncle Mort said:
I use my Boots nostril hair trimmer for that! :tired:
Me too :biggrin:
£3.50 well spent mind :biggrin:
I have a cut-throat at the back of a drawer somewhere - but I have never used it: perhaps I ought to try some day :biggrin::ohmy::ohmy:xx(xx(:tired:. It was my father's.
the anorak said:
don't know about razors but it is true that the first few pringles in the tube have a chemical on them that makes you crave the rest of the tube until you get to the last few, which have the antidote on them !!!!!
once you pop, you really can't stop
But surely: there is an answer to all this!
Open the tube at the bottom.
atbman
Does anyone know where you can get good old Wilkinson Sword stainless steel blades anymore?
Used them for years - only go thro' about 4-5 per year - which may be why they seem to have stopped selling them :tired:
Doubt very much if these 5 blade jobbies are measurably better.
Regarding shaving cream: palmolive out of the tube (the dark green job) applied with a decent brush, works fine, it takes me months to work through a tube. And I shave every day.
And for razors: well I was on GIIs until I found it hard to get blades, so I switched to Excel, seems to work OK. One blade lasts two months. I dislike that strip of white soap (?) embedded in the blade though, I always prise it out on first use of the blade.
gary r
Camberley
Get yourself down to a Turkish barbers,they burn the hairs out your ears with a long stick dipped in alcohol and set alight !!!!:biggrin:
threefingerjoe
I'm one of the mug & brush and soap scraps crowd. Didn't realise that there were so many others!
As far as a professional job from a real barber, I've heard of this fellow on on Fleet Street...:laugh:
I have one of those and barely use it.....it just can't handle the contours of my chiselled jaw line. :laugh:
Seriously though, it just wont work below my chin and leaves me looking smoothe cheeked, but lawnmowered neck.
Tollers
