Rear Brompton lights
shouldbeinbed
Rollin' along
Manchester way
now I've succumbed to the joys of Brompton, I've switched the rear reflector for a simple on/off light & reflector unit from Decathlon that fits the same mount holes and have a Cateye volt 50 that mounts to the saddle rails for my bright as the sun and flash option light.
shouldbeinbed
Rollin' along
Manchester way
can you point me to the relevant Deacthlon unit?
link below
Trelock LS 812 - it fits perfectly to the reflector bracket and is quite a stiff slider power switch so doesn't get knocked or jiggled on whilst the bike is folded the unit is very solidly put together too and allen bolt screwed shut so you've no worries at all that it is going to pop to pieces folded on the tram or in the car. It's lived happily through some pretty heavy rain over the winter and is still running strong on its original AA batteries. The top white diffuser is sensibly thought out and gives a good consistent spread of light across the unit with magnified side illumination.
I'm told the light will flash as a low battery indicator but I've not run them far enough down yet to see it happen.
http://www.decathlon.co.uk/ls-812-trelock-rear-pannier-bike-light-id_8271923.html?LGWCODE=1659100;53453;4414&utm_source=google&utm_term=CYCLE SAFETY / PROTECTION&utm_medium=cpc&utm_campaign=Price Comparison&gclid=CKzRlPH9j74CFTQQtAodXRIAXw
T4tomo
I use a moon cresent USB rechargeable. rubber clips around the seat post so can attach / detach in a second. As I have a longer Titanium seat post it doesnt effect the fold when attached anyway
jay clock
Massive member
Hampshire UK
link below
Just got one. Slightly odd in that it is huge but only has a single LED that diffuses across the top, and the whole bottom 2/3rds is just a reflector. And the nut on one of the bolts is the wrong size so cue tons of ferrying around in old boxes to find a new one. But it looks ideal as fit and forget light
CopperBrompton
Bicycle: a means of transport between cake-stops
London
If you have the budget, there's no substitute for the dynohub. Bright lights, and with the light-sensor (or just left permanently on), they are completely fit-and-forget. No batteries, no messing, just get on and go.
the_mikey
If it's just a front wheel, where can I get a replacement front wheel built on a dynohub?
CopperBrompton
London
Did I mention that it's also gorgeous?
Yellow Fang
Reading
I have one of those. My problem is the cables sometimes come loose folding and unfolding the bike, especially on the rear lamp. Another problem with the rear lamp is that I am never quite sure which mode it's in. It has a three way switch, but I am not sure what the difference is. I have tried various Busch & Muller lamps, but none of them seem to work quite right.
CopperBrompton
London
Not had that issue. I used to leave my lights on S (light Sensor mode) so they came on automatically when it got dark, but on realising that I can't feel the difference between 1% resistance (lights off) and 4% resistance (lights on), I now just keep them on day and night.
