rear cassette issue
gaz911
I have just bought a Specialized Allez Elite from my local LBS.
The ride home from the shop was fine, but after taking it out tonight the gears on the rear cassette are slipping. When I say slipping I mean every say 4 rotation of the pedal the gear will try and change (but not change).
As I spent over £1000 at the shop then I will take it back, but is theresomething I could do, ie its a simple issue and fixable with a screwdriver/spanner.
Sorry I am novice rider and never really messed with the macanics of a bike.
Ta
rich p
ridiculous old lush
Brighton
There is but you should take it back really. Indexing the gears is a skill worth learning though.
Check this site
http://www.parktool.com/repair/readhowto.asp?id=64
ianrauk
Tattooed Beat Messiah
Rides Ti2
Yep, take it back to the shop. As it's a new bike they will index them for free. Then you should take back in a months time as I would be sure your lbs will do a free one months service as the cables would have stretched.
PS listen to the Old Uncle Rich above.. he talks sense.
G
gaz911
Cheers for replys.
Will take back this week, no point me tweaking and breaking it.
On another note how the h'll do I get the pedals off to put on my new ones? I am either weakest man in the world or doing something wrong.
battered
Left hand pedal, left hand thread. RH pedal, RH (conventional) thread.
15mm spanner usually, which is an unusual size in repair kits. DO NOT use a cone spannerif you want it working and not knackered.
Banjo
Fuelled with Jelly Babies
South Wales
Ta
Completely normal for the gear indexing to go out of wack soon on a new bike due to cable stretching usually. 2 minute job for LBS ,ask them to slacken your pedals for you at the same time .
I put a dab of grease on my pedal threads which makes them easier to get off at a later date.
Enjoy the new bike.
G
gaz911
All sorted now. LBS did tighten cable but was issue with chain, one link had been manufactured poorly and was forcing the chain off everytime it hit a cog. LBS changed link and is running smooth now.
Has anyone got tips on keeping the bike clean after rides where the rain has got you? is it as simple as wet cloth and grease on chain?
Sponge and car shampoo. Get some bottles of chain lube, like Finish Line Pro Ceramic.... drip a drop on each roller, spin chain and wipe off excess.
Aerosols waste loads of oil and aren't worth it.
gavintc
Southsea
Most shops will tell you to bring the bike after a week to tweak the gears as the cable will have stretched in that time. The stretch is most noticeable immediately after fitting. It should be OK once it has been reset for a few weeks at least. But, it is worth googling how to do it. It really is a 5 min job - and one worth knowing how to do.
RecordAceFromNew
Swinging Member
West London
Since your bike is new the general advice is NOT to lube the chain for a while until it gets gritty inside the rollers (probably after a few hundred miles for road riding). The reason is that new chains come from the factory with a waxy lubricant, which has the advantage of being excellent for lubrication as well as being neither wet nor sticky like most lubricants people would apply which collect grit and dust, and which are the main reasons for chain wear.
EDINBURGH
If it is a Shimano set up with Shimano cables then it will take about six weeks of regular riding to settle down as the springs in the derailleur stabilize and the cable stops stretching, there is probably an adjuster where the cable enters the shifter or the derailleur that can be used to tighten or loosen the cable tension slightly, that is where you fine tune the indexing. If it is SRAM it takes about three weeks.
e-rider
Banned member
South West
I don't entirely agree with this statement. I would agree that the lubricant that is factory applied is very good but it will need to be 'topped-up' with a decent normal chain lube well before a few hundred miles - if your first ride is in wet conditions you'll need to apply chain lube straight away.
The main reason for (quick) chain wear is not enough lube!
RecordAceFromNew
Swinging Member
West London
The reason for (quick) chain wear is the internal rollers/sleeves being worn down by a grinding paste (based on a mixture of road grit, and wrong lube or right lube wrongly applied). This subject has extensively been covered by the late great Sheldon as well as Jobst Brandt.
Fattman
Roydon, Essex
It can be as simple as that. But pretty soon, it's the clean rag/oily rag, then the degreaser, water dispersant... it ends up with cotton buds and rubbing alcohol and cassettes in the kitchen sink and grumpy wives and divorce and living under a bridge... at least you'll have a clean bike, mind!
