- Inside my skull
Putting a wet dirty Brompton in the boot of a car will not have helped matters.
ALL rim braked small wheels have a shorter life than 'full sized' rims.
Bromptons used to be known for lacklustre braking. Fitting a more aggressive block sorted that, but at the expense of wear on the rim. My badly treated commuter on 700C rims managed about 4500 miles before the wear indicator showed a new rim was needed. As 10 out of my 16 mile each way commute was on little used country roads, and 3 was on A roads, the real wear took place on wet days in town.
Just for the record. Mine is on 4 years and 6500 miles and the rear rim is ‘going soft’ on the drive side. That means I can dint it with a flat screw driver. The drive side is worst because it catches the oil from the chain. This collects dirt, which turns into a grinding paste. I clean the rims when they look grey. I also use brake pads that are designed from aluminium rims. The blocks do last about 1800 miles and not cheap.
. Handy of them to put in a weak spot from a split to follow !
Ah! Finally an answer to the question in my head ! So the groove running round the rim is the wear indicator ?. Handy of them to put in a weak spot from a split to follow !
So if you go beyond the limit of the wear indicator the rim should look perfectly alright!![]()
I was just looking for this thread to point someone else to, but thought I'd update that the replacement wheel was going strong up until a month or so ago, when I replaced the lot as the hub sounded awful. Grinding and general unpleasant.
Still not got around to fixing the old one, but have bought the parts. As I lost some of the bearings when I took it apart to see how it worked. D'oh.
What I would say is that I still think the original wore out too soon. After this thread, I started cycling that hill every day and the replacement wheel lasted a further 5,000 miles and didn't show any signs of wearing through...
What are peeps thoughts on softer pads than the standard issue such as Koolstop Salmons to reduce rim wear?
I've had about 20,000 miles out my Mavic A719s, with fairy abrasive Shimano M55/T blocks. That would be equivalent to about 12,000 miles on a Brompton with smaller wheels.As it is, my Strava log indicates that I've now done around 10,000 miles on the Brompton and the rear wheel looks OK.
It's miles, riding style, cleanliness of the bike, weather, type of breakpads, weight of the rider, speed, surface you are riding on, anxiety of the riderBut it's not the time, it's the miles and it does sound as if the OP puts more miles on than I do.
(how often does he break?) and probably a couple things more. One of those is obviously the type of rim itself. Also, it is quite typical that the rear rim cracks earlier often, for one as it is typically grittier than the front and second a lot of riders use the rear brake intensively on the Brommi. So a lot of things that influence the lifespan and a lof of influence of the rider.Cleaning the bike and lubing the chain once a week will increase the MTBF. It's 15 minutes well spent. If you ride a lot and in bad conditions it's 15 minutes even better spent.
At 3.400 miles @Kell is at the lower (but not the lowest) part of the distribution in terms of rim lifespan. The majority seems to be between 10.000km and 25.000km, with a peak at around 20k km. However, sportier riders with a harsh riding style are typically way lower than that.It's miles, riding style, cleanliness of the bike, weather, type of breakpads, weight of the rider, speed, surface you are riding on, anxiety of the rider(how often does he break?) and probably a couple things more. One of those is obviously the type of rim itself. Also, it is quite typical that the rear rim cracks earlier often, for one as it is typically grittier than the front and second a lot of riders use the rear brake intensively on the Brommi. So a lot of things that influence the lifespan and a lof of influence of the rider.
I do have my doubts that lubing the chain increases the lifespan of the rims but who knows.At 3.400 miles @Kell is at the lower (but not the lowest) part of the distribution in terms of rim lifespan.
If I was @Kell I'd probably give the Sun CR18 a try - it is a dog to put tires on but rumors say it would be way more longlasting than other Brompton rims.
silver
black
