Replacing a triple outer chainring with double?
Aston
Earlier in the year I bought a double 46T chainring for my Thorn Club Tour by mistake, not realising this would be slightly wider than the triple it was to replace.
Is there likely to be a problem using the wider outer chainring other than sitting a bit proud by maybe 0.2mm? Both chainrings are Shimano SG—X
Thanks
Paulus
Barnet,
The obvious thing is that the front mech will/might need to be adjusted, probably by the limit screw.
I'm sure someone will come along with a more substantial view.
All uphill
Still rolling along
Somerset
I didn't know chainrings for doubles are a different width than those for triples, and have often swapped rings between bikes without problems.
AI also doesn't know of different chainring widths.
Maybe I have misunderstood your question. Sorry.
