Replacing tyres
Aston
I know this is a bit like asking the same or about oil on a motorcycle forum, thousands of different opinions, but I just need a steer in the right direction.
I have an elderly, rebuilt Thorn Club Tour, I'm using for 10-15 mile rides weekly, but intend to take some longer weekend/three day camping trips with loaded panniers and tent. The bike currently wears Panasonic Panaracer Pasala Tour tyres, 700 x 32, however if I need to remove the front wheel to transport the bike I need to deflate the tyre to get it past the brake blocks (on cantilevers).
Both tyres need replacing, the rear has a cut in the sidewall with a bulge. I was thinking of just replace like with like, but two beginners questions...
1 - Should I opt for a small section front tyre so I don't need to deflate it?
2 - I quite like the Panasonic tyres, but at £30 each wondering whether there's anything else cheaper which would do the job with some puncture resistance
or is it just a case of bite the bullet, spend £60 on replacing them?
Thank you :smile:
Profpointy
At the risk of teaching my grandmother to suck eggs, is there a flippy lever or equivalent to release the brakes entirely to get the tyres out. This can be on the brake levers or the brakes themselves
Here's what's on my Condor. My own Thorn is in bits so can't quite remember what it has / had. Thorn are a solid make so I'd be surprised if it doesn't have something like this.
In the unlikely event it lacks such a thing, then I'd get new levers, or new brakes, or an aftermarket a accessory brake hanger thingy rather than be constrained for tyre choice.
Aston
Aston
No drops, it's set up with butterfly type bars and shimano deore lx shifters, so I don't have that option.
Profpointy
Presumably could still unhook the wire from the straddle cable bit - I think on mine you could unhook the straddle cable itself from one side; or as I say retrofit with the flippy cam acceossry things.
T4tomo
yes if you squeeze the brake blocks onto the rim with your hand, that usually allows you to unhook the cable from the Canti mechanism.
also there is usually some sort of fine adjuster somewhere in the cable run or at the brake lever or a hanger pivot, that can be slackened to make the above more achievable or to allow the tyre to slide out un-deflated.
T4tomo
to the OP: oh and panaracer pasela PT's are a very good tyre choice for that sort of bike / riding, and I wouldnt go narrower, you will sacrifice comfort, you just need to spot the knack of slackening the brake caliper.
or is there really isnt anything then introduce a cable adjuster see below pic - I put some on Mrs ts bike when doing that up....
Aston
Aston
Thank you, I hadn't thought of unclipping the brake cable, I'll give it a go. Thanks again 👍
si_c
Wirral
If you're looking to replace the tyres, you could opt for Vittoria Zaffiro Pros - they're around £21 each, but I wouldn't want to spend less than that.
To my mind if you're happy with the Pasela's then I'd replace like for like, they've a really good reputation for comfort and durability (not ridden them myself though) and if the current pair has lasted long enough to need replacement then presumably you're happy with them.
Tyres are an area where I think it's worth spending the money on consumables though.
