Require a wheel replacement
Hi5oka
DRM
West Yorks
Second hand 700c disc wheel set, a replacement will cost nearly as much, if not the same as the bike cost as it's a disc brake set up new, as well as the lack of availability right now, you will also need quick release skewers for both wheels, the below are the cheapest I can see available right now at £265, the bike isn't worth spending that much on to be honest
https://www.wiggle.co.uk/mavic-aksium-disc-6-bolt-wheelset
https://www.wiggle.co.uk/hope-steel-rod-road-quick-release-skewer-set
T4tomo
I'd buy a new bike, then you have a source of more parts. I love the fact that it has a kickstand!
what material are the wheels made from? some sort of plastic / resin?
